Hmmm… I don’t recall this. Maybe there has been a solution all along!
@DanBayn, here is that post which mentions a workaround.
@Steven_Elliott, your problem seems to be related to the bug i reported here.
c.
Wow it seems thats the exact issue im having. Although still do not see a fix
I tried adding import scriptcontext… no luck. Ill keep my eye out for a solution. Thanks for the links
that only is related to the problem Dan reported, your problem is a different one.
c.
Somehow I missed this completely. I’m going to give this a try on Monday.
Thanks for the links.
Dan
My issue is solved. Thanks @clement for pointing this out, and thanks @stevebaer for fixing this. I usually am able to keep up with the posts but somehow this fix slipped past me.
Wouldn’t have happened in the old newsreader newsgroup! ha ha, just kidding!
Dan
You Dan’osaur, you.
