C # is used to simulate the function of the close points component, but the speed is much slower. How to speed up the script.
design_1.gh (9.9 KB)
Due to the large list, even a C# script with no code will take more time loading than default Closest Points component computing.
For the reason, read this:
Rhino have already a class for “a list of points”, the PointCloud class.
PointCloud class have a method for closest point search.
Then, because you want the Closest Points , a small “trick” was needed to recover the correct indexes…
design_1 re.gh (14.5 KB)
private void RunScript(Point3d P, List<System.Object> C, int N, ref object Pt, ref object i, ref object D)
List<Point3d> pts = new List<Point3d>();
for(int j = 0;j < C.Count;j++){
pts.Add((Point3d) C[j]);
Rhino.Geometry.PointCloud cloud = new Rhino.Geometry.PointCloud(pts);
Rhino.Geometry.PointCloud cloudbackup = new Rhino.Geometry.PointCloud(cloud);
List<Point3d> points = new List<Point3d>();
List<int> indexes = new List<int>();
List<double> distances = new List<double>();
for(int j = 0;j < N;j++){
int k = cloud.ClosestPoint(P);
Point3d pt = cloud.PointAt(k);
points.Add(pt);
distances.Add(pt.DistanceTo(P));
cloud.RemoveAt(k);
indexes.Add(cloudbackup.ClosestPoint(points[j]));
Pt = points;
i = indexes;
D = distances;
Thank you for your reply. I’m very excited. I will try it as soon as possible.
