Issue with python editor
Any ideas?
I have tried resetting the system paths to the default, resetting the PythonEngine as well as restarting Rhino. All failed to solve it.
This happens only if I have something imported like from somepythonfile import *
Below that line I get no function hints.
Windows (PC) restart also doesn’t fix the issue.
In fact even if it is not * the function hint fails.
even if it is from something import something
Never had this issue before today.
This is the version I have: 6.15.19141.08361
Will install now: 6.16.19169.11231
Issue is still there
Looks like an example of a longstanding bug which appears to still be open:
If you search discourse for autocomplete or intellisense you’ll see lots of problem reports over the years :unamused:
That’s very weird.
Pity noone is even working on that issue and it was created 4 years ago. :thinking:
No problem here in the Rhino Python editor in Rhino 5
###  TEST CODE TEMPLATE      ###
import math
from Rhino import DocObjects
rs. # autocompletes normally
hmm I even get that when just:
import myscript
and also when the thing you import is none existent
(6.14)
but does it also happen after you run the script once? here it ā€˜fixes’ the issue
I think it is not the from but importing a custom script that causes it
edit: just tested it in rhino 5 and same issue
so to work around: run the script once and you get your intelliSense back
by the way, don’t do this: from add_clipping_plane import * because explicit is better than implicit
This isn’t true.
I wrote the intellisense system that the current editor uses and there are many ways to break it. You found one. I believe I even called it intelliclunk in the UI.
Ahh yes I do get that if I import * from a module which contains nothing…
I’m sorry, I was referring to the:
Any way to fix that?
I’m pretty sure before today I have never experienced it.
I do this only when it’s created by me and I have 2-3 methods inside. :slight_smile:
To save typing 2 or 3 methods ? :slight_smile:
to obfuscate what I’m doing there :smiley:
to be honest, before I started doing that I really didn’t find reason to split my projects in multiple files. But as it turns out the same method can be used in many projects and I naturally started splitting them all :smiley:.
I always learn the hard way.
Not with the current system. Alain is investigating a completely new architecture for providing autocomplete in the future. Still just in the investigation stage though
Not this time: this time, in 6 months when you have forgotten which method came from where, you will be glad you listened to me :wink:
That’s not gonna happen since, like I said, I only have a couple of methods in each file :wink: and I hate using import * in cases when the file is not created by me.
here is one way that might fix it:
