EditPythonScript Mac issue
@Alain I notice on Mac that the code autocomplete stops working when I type code in between other code. In other words, it only seems working when I add code below existing code (I’m using Rhino 7.2)
Hi, there are known issues in these cases. Would you mind sharing your script?
@Alain it happens in every code when there is something below the line I am typing, even an empty line (enter):
as you can see in the above image, there is an empty line 2. Backing my cursor to line 1 and typing import, will not give me the import until I remove the enter:
Sorry about that. A fix has been made and will be in the 7.4 service release.
Thanks for reporting it.
