new kid on the block (who is old here…): Nodi
I can’t find isopod in food4rhino,did anyone can send me a download link?
…and yet another one: Morphé by metomorphic just dropped yesterday
I’m trying to create a TPMS surface in a frame.
I think I’m approaching this wrong - I’m thinking in solid boolean operations instead of fields, maybe?.
There must be a better way.
Isopod_Framed_TPMS.gh (100.3 KB)
Hi Martyn,
Here’s a way of approaching this. As the rounded boxes have a simple mathematical form, they make it faster to compute than using something like the MeshSolidSDF object on some already created Rhino geometry.
Working through creating this example though I see there’s a lot I’d like to improve about the next version, as I realise it’s not a very intuitive workflow.
Thanks Daniel,
I think the file you uploaded was the original one I posted but I can recreate your solution from the image!
Regards
Martyn
Sorry, indeed it was! Here’s the right file
tpms_frame.gh (37.5 KB)
Brilliant, thanks.
One question… I seem to find it unintuitive to make tweaks to the final shape.
An example… I want to make the thickness of the gyroid part the same thickness as the frame so it is neither recessed or standing proud of the frame.
My intuition tells me to adjust the Box used for Frame Depth but I can see this box is about right.
Why is the frame in the end result thicker than the Frame Depth box?
I see the issue here. The way the rounding was applied to the box field, it was also producing an offset. Here with the box field script modified:
tpms_frame2.gh (34.2 KB)
Thank you Daniel for this other amazing addition to Grasshopper.
I’m trying to design a 3D lattice structure with a specific particle-guiding behavior.
The idea is to place a perforated plate on top of the lattice, with holes smaller than the lattice channels. A small sphere can pass through one of these holes and enter the lattice.
I would like the lattice geometry to ensure that, regardless of where the sphere enters, it is always guided towards a lateral outlet rather than falling through the bottom.
The bottom face of the volume would be completely solid (closed).
Is there a way to design such a 3D lattice geometry? What type of unit cell, topology or geometric strategy would you recommend to achieve this behavior?
Hi Olivier,
I don’t understand the constraints here.
Stopping the particles leaving through the bottom seems easy if that is a solid plate.
If the top openings are small compared to the ones on the sides it seems they will be more likely to leave from the sides, but wouldn’t almost any geometry achieve this?
Should they leave from any of the 4 vertical sides, or just the 2 left and right in your image?
Are these particles moving under gravity?
Hi Daniel,
Thank you for your quick reply.
You are right. I forgot to specify that I am more interested to use TPMS, gyroid type of lattice. And I feel that gyroids may create cavities that could avoid the particles to escape.
Also, having the particles sitting at the bottom is not good. I would need them to exit the geometry before they reach the bottom.
I would like the particles to escape through 3 vertical sides only, the 4th would be closed also.
Yes particles are moving under gravity only.
To give a bit more of context, I am working on the sole of a sandal. I want little stones entering by the top surface of the sole to be forced out to the front, left and right sides to leave the interior of the sole rather than staying inside at the bottom.
Don’t you think it is a bit of an overkill trying to simulate this?
Would make a beautiful lamp!
If you search up this topic for where @laurent_delrieu creates blocks that allow light to pass through creating different shadows in different directions, you could adapt this to allow larger gyroid openings on the 3 sides you want your spheres to exit.
You may be right. I will try to lower my criteria and try a simpler more solid solution.
Thanks.
Ok. I will try to adapt the Laurent’s technic.
Thanks.
