Just scratching the implicit surface of a new plugin via the PackageManager command called Isopod… lots of ideas here!
Hi Brian
Awesome render!
How did you setup that glass material?
The glass mat is the default and the water in it is a glass mat with the IOR set to water. The set up is pretty simple with one of the library environments for skylight and reflection along with a rectangular light. Here’s the 3dm without the isopod meshes which make the file much larger.
glass.3dm (9.5 MB)
Such a simple setup, sutle depth of field, but a great result!
I really struggle with Rhino post effects, most of the time I can’t get a good combination of values, and there isn’t a “default” that we can return to, so I tend to not use them at all.
I also use the 2 colors gradient bg sometinmes to give my renders an easy studio look.
Thanks for the file!
