in rhinoscript: what differences between “iscurvelinear” and “isline”?
IsCurveLinear test a curve to see if the locus of its points is a line segment. IsLine test to see if a curve is a line curve object (ON_LineCurve) or a 1-degree NURBS curve with 2 control points.
– Dale
thanks @dale for answer,
same curve with displaced control point and different result with “Rhino.IsLine”
is the right result?
Yes I see that - thanks for reporting.
https://mcneel.myjetbrains.com/youtrack/issue/RH-53851
– Dale
thanks Dale
