Test Curve Linear & Degree 1
Hi All,
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.curve/islinear
the method indicated in the link checks if a curve is linear, but to check if it is also a simple straight line with only two control points, I have to check if it is of degree 1 right. . . there is no specific method?
Curve c;
var b= c.IsLinear(0.001) && c.Degree == 1;
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.curve/degree
ok @Tao_Lin thanks for reply :+1:
Not exactly …
A Polyline may be linear.
Just look at what rhinoscriptsyntax does
def IsLine(object_id, segment_index=-1):
    """Verifies an object is a line curve
    Parameters:
      curve_id (guid): identifier of the curve object
      segment_index (number, optional): the curve segment index if `curve_id` identifies a polycurve
    Returns:
      bool: True or False indicating success or failure
    Example:
      obj = rs.GetObject("Select a line")
      if rs.IsLine(obj):
          print "The object is a line."
      else:
          print "The object is not a line."
    See Also:
      AddLine
    curve = rhutil.coercecurve(object_id, segment_index, True)
    if isinstance(curve, Rhino.Geometry.LineCurve): return True
    rc, polyline = curve.TryGetPolyline()
    if rc and polyline.Count==2: return True
    return False
