I am trying to find an object and one useful way would be to display one at a time the solids or surfaces created going backwards in time.
Does such exist ?
Steve
Does such exist ?
Steve
Not that I know of. Here is a quickie script that will scroll back in time through all normal objects - those that are not hidden or locked - and select them one at a time. Enter, spacebar or right mouse click to continue scrolling back, Esc to stop. Last object selected stays selected.
–Mitch
import scriptcontext as sc
def ScrollBackInTime():
objs=rs.NormalObjects()
if objs:
for i in range(len(objs)):
rs.UnselectAllObjects()
rs.SelectObject(objs[i])
msg="Object #{} selected.".format(i+1)
check=rs.GetString(msg+" Press enter to continue, Esc to stop")
if sc.escape_test(False):
break
print "Oldest object reached, exiting function"
ScrollBackInTime()
Hi Mitch,
many thanks…
What if an object is on a layer that is turned off ? Does that count as hidden or is hidden referring to the Hide command ?
I trust all these wonderful scripts etc will feature in V6 ?
Steve
Yes, all objects that are not selectable will be ignored.
Probably not. It depends if there is a high demand for this sort of thing or not.
–Mitch
