Do any users know of a command which can select all Scaled Blocks and/or non-uniformly scaled blocks?
I can see there is are options for SelMirroredBlocks and also SelBlockInstanceNamed, however nothing which can select ‘Non-uniformly scaled blocks’
It would be a nice ‘quality of life’ tool to help clean a facade model.
Thanks
i have never used it but maybe BlockResetScale or ResetBlock.
Rhinoscriptsyntax has BlockInstanceXform
Copilot helped me put this code together:
import math
def has_non_unit_scale(xform, tolerance=1e-6):
# Create basis vectors using proper Transform component access
x_vector = rs.VectorCreate([xform.M00, xform.M01, xform.M02], [0, 0, 0])
y_vector = rs.VectorCreate([xform.M10, xform.M11, xform.M12], [0, 0, 0])
z_vector = rs.VectorCreate([xform.M20, xform.M21, xform.M22], [0, 0, 0])
# Calculate scale as vector lengths
scale_x = rs.VectorLength(x_vector)
scale_y = rs.VectorLength(y_vector)
scale_z = rs.VectorLength(z_vector)
return (
math.fabs(scale_x - 1) > tolerance or
math.fabs(scale_y - 1) > tolerance or
math.fabs(scale_z - 1) > tolerance
# Loop through all block instances in the model
guids = rs.AllObjects()
for guid in guids:
if rs.IsBlockInstance(guid):
xform = rs.BlockInstanceXform(guid)
if has_non_unit_scale(xform):
rs.SelectObject(guid)
print(f"Scaled block detected: {guid}")
forgot to mention that with these 2 commands you might be able to just select all blocks at once. but what if you have different blocks that are scaled? so that might require to have a file that has only one kind of block
