Is Rhino storing the object transformation
Is Rhino storing the transformations of an object?
For example, if I create a sphere in 0,0,0 and 5mm radius, and I modify it using the gumball, is there a way to know that it was a sphere of 5mm?
Thanks,
You basically ask two questions. Rhino doesn’t store object transformations. But moving a sphere of radius 5 will not alter the fact that it is a sphere of radius 5
Thanks for your answer!
Sorry, probably move was a bad example, I was thinking in scale and rotate too. :slight_smile:
Thanks,
Again the answer is no, Rhino doesn’t store deformations.
With the exception of block instances.
Can you explain this one a bit more? Where can I find the translation, rotation, and deformation of a block instance?
InstanceObject.InstanceXForm gives you all the transformation information.
https://developer.rhino3d.com/api/RhinoCommon/html/P_Rhino_DocObjects_InstanceObject_InstanceXform.htm
@Gijs as @rgr says.
