Is it possible to write a Python script to realize the function of path mapper? for exampe {a} -> {a + 66}
Hi everyone,
The path mapper is a powerful function to change the data tree path, however, if I want to realize it using a Python script, how should I do?
Thanks!
Capture
use the renumber paths string method.
In general via code you can do anything imaginable with regard path(s) dimension indices.
But if you insist on GH_Lexer.PerformLexicalReplace matters translate the attached (and modify it accordingly) into P - note: no auto translation available.
Lexer_ops_V1A.gh (40.2 KB)
