When I import my mesh from Lidar scan, I need the features on the texture file to help align the model to X,Y,Z model space. Then I like to quadremesh to get a smooth mesh, but I lose the detail I need later on in my workflow…
Can I have my cake and eat it too and have the Quadremesh re-mapped with the textures?
When I select my mesh that IS textured, the triangles are so dense that it is just a yellow blob when I select it to rotate/align… when I zoom in close enough to see the texture, I lose perspective of where I am on the mesh… its like a Catch 22. Was hoping the quadremesh would resolve this issue.
Is there a way to select an object but dim the “selected yellow”?
Hi Chris - you can set the display of the selected mesh to use ‘shade highlighting’ in the display mode settings - that is not ideal but the best we’ve got right now.
Quadremesh should eventually be able to reset the textures, eventually, but that is not a solution to your problem - or, it would be a very backwards workaround - the real solution is a non-obscuring hightlight.
RH-31739 Selected object highlighting - more options
Hi Pascal
is this in the latest version 8 now?
and can it / will it be usable in a partial selection?
i.e in the image here you can see how the mesh is distorted as the 3d scan software has tried to patch missing points, I would like to edit this to look better in Rhino, but I am keen on being able to keep the texture so it looks like a window glass pane still.
is this possible?
