When I model facades, the files can become quite large and i’m curious if you could bake single surfaces out of GH with the thickness object property pre-applied. In the case of mullions, I can model them as single surfaces and use the thickness object property to apply width without having to create a polysurface. Is this something that can be set up ahead of time in GH so they bake with the properties already configured? Could this be done with curve piping object property with curves as well?
it seems like “Rhino.DocObjects.RhinoObject.Attributes” contains the Thickness flag and infos, but I wasn’t able to isolate it.
This small script takes the whole “.Attributes” from a referenced geometry, and bake a new geometry using it (giving it the same color, layer, etc, etc, and thickness flag).
So, set as reference a geometry with thickness flag (you can’t internalize it).
