Is Gumball's drag strength broken?
Hi All, I wonder if gumball’s drag strength is working?
I don’t see any effect in these versions of Rhino:
Version 7 SR36
7.36.23346.16351
Version 8 SR7
8.7.24113.23001
Well, now I see that the strengh dialog needs to be open for the tool to work, I though that this was just something that could be sticky and enabled or disabled.
Apparently in V5 it works in a different way.
Hi Joaquin - use DragStrength for all dragging - including Gumball - does that work?
Hi @pascal , yes it works, it just doesn’t work the way I expected.
I got the dragStrength dialog box from the white circle from the gumball, the same that appears if you use the DragStrength command you mentioned. But I though that the setting was persistent like in V5.
I would like the option to enable or disable it without having the strength window open.
This is naturay is part of bigger request of a more integrated geometry manipulation tool we really need.
You need this: :smiley:
I have a colleague that’s been struggling to choose to continue using R8, now I have to add this, today, to the pile of reasons. :expressionless: frustrating.
It would be nice if there’s some workaround script or something, maybe some way to use macro buttons that hide the strength dialogue too…
