Is there a way to Chamfer to a specific degree?
I’m doing a speaker cabinet and just for modeling sake, I want to do a 45 degree angle on an intersection.
I thought if could’ve been just easy with chamfer.
My process for the fist picture was
Intersect > Draw Line from Intersect to Edge > Extrude Curve > Boolean Difference
I did that in both surface. Now the reason why I used the command intersect was because I found some inconsistent behaviour with Int object snap.
Anothar way thing it is to boolean as intersection but we are just left with a squared column.
Any ideas for saving time?
When doing cabinets I mostly use Blum’s online service and you modeled it with the intesrsection cuts so that’s cool for reference.
Not sure about the chamfer specifics but an alternate miter method you can do is the following command macro (I think Pascal shared this at one point?):
! BooleanSplit Pause InfinitePLane Vertical Pause <45 Pause Enter
Nope just a macro with a toolbar icon linked to it.
A macro is a series of Rhino commands strung together to expedite what would be an otherwise longer sequence of entering multiple commands one after the other.
So this “miter” macro:
is running a boolean split operation using a plane, the vertical plane is defined when you click the two “miter points”
Macros can be very powerful and efficient when used effectively
