Hello
Is there a code to find the inverse sinc function?
sinc(x) = sin(x)/x
akilli
(Ethan Gross)
2
Doesn’t seem like it would be well defined. For a given y, there could be many x’s. You’d have to specify a neighborhood of x.
Hey!
I think you can have access to Sinc function by loading Numpy library.
https://numpy.org/doc/stable/reference/generated/numpy.sinc.html
I use a law in this page, it give an approximate result by solving the equation and find x
This is the best solution i found right now
This is another way with better precision (≈100%)
I will try to make it as python code if this is possible
