invalid mesh.gh (18.6 KB)
Hi everybody,
I am trying to transform some surfaces into mesh, but I always get an invalid output. I use diamond panel (lunch box), in order to create the surfaces.
Do you have any suggestion?
thanks in advance
Hi everybody,
thanks in advance
Because in Rhino 6 meshes are more strict. Your triangles are quads with a collapsed edge. You can fix it with the small c# script I provided here: Mesh Surface (Mesh UV component) makes Invalid Mesh with Spheres (Rhino 6 + GH 1)
Alternatively in your case, if the goal is single mesh faces you can just use the “Simple Mesh” component.
The “Mesh Brep” component won’t give you single faces always.
Did you try the “simple mesh” component?
Thank you! I use the simple mesh component before your script and it works!.
