Intersection Multiple Breps and Multiple Curves
Hi everyone,
I am trying to find the intersection between several spheres and several curves, with no luck using Brep Curve intersection.
I would also need to keep the list structure, so ideally something like
{0}
Point 1
Point 2
Point 3
Point 4
{1}
Point 5
Point 6
Point 7
Point 8
Input Spheres
Input Curves
Input Combined
Script
Current result
Desidered result
Many thanks in advance,
S
Breps_Curves.gh (55.8 KB)
you’ve found all intersection points. could you clearify what you like to achieve?
Hi, yeah sorry. I added a screenshot showing it. Cheers
GH files with internalized geometry are WAY BETTER than screen shots.
Flattening is often a mistake.
Hi, you are indeed right. Question now updated, script attached. Many thanks.
Breps_Curves_re.gh (56.5 KB)
make sure that all curves intersect all breps
Neither the groups of points nor the points within each group are sorted.
You also have duplicated spheres at each grid point. You can reduce your sphere count fr 252 to 126.
Thank you so much, everyone!
I added a bit of script to sort the points.
Too bad the points aren’t sorted consistently around each sphere. I tried many ways myself, the white group in this model being only one of them. They all failed and I don’t know why?
Breps_Curves_2021May18a.gh (76.3 KB)
