the routine Intersection.MeshPolyline seems to miss the intersection for the mesh and the line
on layer default from attached file bad_mesh.3dm (88.5 KB)
The intersection within doc tolerance exists If i try to snap to it
Any hint or suggestion to detect this case ?
gerry
Looks like there is a very small gap between the edge of the mesh (x = 32.804420471191406) and the line (x = 32.804420945913783) that is causing the intersection to fail.
Hi Dale
Thanks for looking at this, but with a tollerance set to .01 shouldn’t the intersection get trapped ?
We are talking about the 7 digit , far smaller than a micron. The line has been placed using snap near tools, so something is wrong with the intersection detection
The method you’re calling does not use the document tolerance.
Internally, the code first test to see of the line intersects the object’s bounding box. This is to eliminate the obvious false cases. Note, no tolerance is used here. This is where the failure occurs in your case.
Had the bounding box intersection succeeded, Rhino’s internal zero tolerance (2^-32) is used for the mesh intersection calculation.
Hi dale I got it but something is wrong for me. Same lines placed at other edges are all detected, placement is done using the snap near tool. One line missed over a set is more like a small bug. None of them or all of them should be the result. I don’t think that the bounding box is not inflated by a eps before first intersection test
We’ve been discussing this internally lately. There’s not much at present.
But I am wondering, if you were needing something for mesh|curve or mesh|polyline?
Thanks,
Giulio
Giulio Piacentino
for Robert McNeel & Associates giulio@mcneel.com
Hi Giulio
I needed a mesh curve but moved to mesh polyline since it was not available. I am working on a tool to convert a model made out of curves, surfaces meshes into a fem model ready for analysis
