Intersection Brep Brep
I would like to insert fasteners between the two panels. With a variable distance from the outside and us separately on the inside. To do this, I have created the intersection between the components. Unfortunately, I can’t get any further. The fastener should be inserted from a separate Rhino file. I would be very grateful for help.
Best regards Michael
Forum.gh (22.9 KB)
Mesh intersection creates invalid mesh so nothing works further
i tried another way round may be it suits your requirments
Forum_RevA.gh (20.6 KB)
Thank you Rajeev, it works perfect but now i want insert some Rhino files with different fasteners. How can i bring them on the right position?
Thank you so much
Try using the Orient component.
-Kevin
it works thank you
I guess you figured it out, but I just finished this:
One solution, I’m sure there are many others.
-Kevin
The problem with this solution is, that my fasteners are not in the same deep in each object. Do you have a solution that the created z-plane direction goes into the horizontal objects?
In the picture, the left one has the wrong way of z, in the right one its correct…
grafik
Forum_RevB.gh (22.9 KB)
@Rajeev2 if I understand correctly, this is what @michael.haertlein is asking for:
I’ve edited the file Forum_RevA.gh that @Rajeev2 uploaded.
This is the result
Forum_RevA_edited.gh (31.3 KB)
-Kevin
Thank you its a perfect solution :slight_smile:
@kev.r Thanks i do miss that its awesome
