Hello there,
I just wondered if there was a way to intersect 3 planes (=PlanePlanePlaneIntersection), resulting in a point…
I did not find anything in the rhinoscriptsyntax, I guess I am not too profound in RhinoCommon.
I could pretty much think of a workaround: Intersecting 2 planes and then intersect a line with the last plane, but maybe there is something more elegant?
Thanks,
T.
Hi @tobias.stoltmann,
There is Intersection.PlanePlanePlane method:
import Rhino.Geometry as rg
succ, interscPt = rg.Intersect.Intersection.PlanePlanePlane(pln1, pln2, pln3)
@djordje, Thanks a lot.
I should have seen that myself.
So I have one more question (which shoudl acutally be asked in another thread here).
Is it possible to have an intersection from a point a vector would be starting with a plane?
I am creating a line so far and am using PlaneCurveIntersection so far, but I guess there must be something more elegant, right?
Thanks,
T.
So an intersection between a vector (from a given vector start point) and a plane?
Did I understand that correctly?
If rs.PlaneCurveIntersection is working, you can use that one as well.
This one works too, and considers the vector as an infinite length:
vec_length = 10 # any value. Does not matter, as it will consider vector to have an infinite length
ln = rg.Line(startPt, vec, vec_length)
succ, interscT = rg.Intersect.Intersection.LinePlane(ln, pln)
if succ:
interscPt = ln.PointAt(interscT)
