There is any away to check the IntersectBreps (trimed surfaces) wihout draw the curves?
I have a loop that check and delete it right away, but even with redraw deactivated, it creates a slight delay that I would like to eliminate.
Any other away?
Any other away?
Drawing what curves? Perhaps we need more information and/or a code sample?
– Dale
Hi @dale
Using sample code:
brep1 = rs.GetObject("Select the first brep", rs.filter.surface | rs.filter.polysurface)
if brep1:
brep2 = rs.GetObject("Select the second", rs.filter.surface | rs.filter.polysurface)
if brep2: rs.IntersectBreps( brep1, brep2)
Thanks
Hi @MatrixRatrix,
Here is the Python code behind rs.IntersectBreps. With this, perhaps you can write your own function does not add curves to the document.
– Dale
