The column,the wall,the beams intersect,how to find the intersection surface,and the column,the beam,the wall is divded by the intersection of the surface?For example,A or B.
Hi @gxyanjiaju,
If you are using RhinoCommon, then you might want to use Intersection.BrepBrep.
– Dale
Can you code it? Because I use Brepbrep, but I don’t use it very much
