Intersect multiple lines
At the moment i am trying to intersect multiple lines with eachother, but it doesnt work. In my file there you can see there are horizontal and vertical lines which i want to intersect. But now it just intersect a couple of points but not all of them. How can i fix this?
IntersectTest.gh (42.0 KB)
You 'd be better off grafting one of line input. Otherwise there would be some data mismatching happen.
IntersectTest_re.gh (15.6 KB)
Hi Kim, Thank you very much! It works now, but now i got an other issue, I have grafted it and i want to let those points make lines over the y and x axis, so they connect like an square with end and start points. I am trying now with list select and kind of solutions, but now i only get a drawn line in the Y axis and not the X axis.IntersectTest.gh (48.9 KB)
I don’t understand what are you going to to… There are probably simple and easy ways from the beginning.
IntersectTest _rev2.gh (15.5 KB)
I have figured it out what i needed in my other file. I wanted to make an intersection, and then make an poly line between the points, explode them, so they keep the same distance between the points and then i can connect those to Karamba (making beams of lines). Thanks for all the info Kim! Really appreciated!
