Dear All
I’m writing here after several years to ask your support.
I’ve n point (5 in the attached image) and I’would like to create an interpolate nurbs curve (4 degree curve) that fit all the best these point.
I’ve tried with the standard command, but basically what GH do is to get the first and last point fixed and fix che curve around the other point.
I wuold ask if is possible to create a curve that also “move” the start and end point also.
Just to understand in the first image in blue you will see the standard result, the dotted line represent the 1 degree curve, the green line what I want.
Maybe the mathematical issue can be minimize the integral between the 2 curves 1 and 4 degree (dotted and green one), or polinomial regression???
