p-e-t-e-r
(Petr Klimenko)
May 23, 2024, 9:48am
1
Description of the problem: There is a class Joint, it has JointGoo. There is a parameter JointParameter. When you click “Internalise” on Grasshopper and then copy a Parameter, all data from it is reset. Why might this happen?
This is what the properties of the Joint class look like:
public class Joint
public int NodeID { get; }
public Point3d Origin { get; set; }
public List<Arm> Arms { get; set; } = new List<Arm>();
public List<Chock> Chocks { get; set; } = new List<Chock>();
public List<WasherL> LWashers { get; set; } = new List<WasherL>();
public List<WasherS> SWashers { get; set; } = new List<WasherS>();
public bool IsValid { get; set; }
p-e-t-e-r
(Petr Klimenko)
May 23, 2024, 9:51am
2
JointGoo:
using Grasshopper.Kernel.Types;
using Grasshopper.Kernel;
using System.Linq;
using Rhino.Geometry;
using System;
using System.Collections.Generic;
namespace StructuralJointsDesigner
public class JointGoo : GH_GeometricGoo<Joint>, IGH_PreviewData
#region constructors
public JointGoo()
this.Value = new Joint();
public JointGoo(Joint joint)
if (joint == null)
joint = new Joint();
this.Value = joint;
public override IGH_GeometricGoo DuplicateGeometry()
return DuplicateJointGoo();
public JointGoo DuplicateJointGoo()
return new JointGoo(Value == null ? new Joint() : Value.Duplicate());
#endregion
#region properties
public override bool IsValid
get
if (Value == null) { return false; }
return Value.IsValid;
public override string IsValidWhyNot
get
if (Value == null) { return "No internal Joint instance"; }
if (Value.IsValid) { return string.Empty; }
return "Invalid Joint instance";
public override string ToString()
if (Value == null)
return "Null Joint";
else
return "Joint " + Value.NodeID.ToString() + " (" + string.Join("-", Value.LWashers.Select(w => w.LineID.ToString())) + " arms)";
public override string TypeName
get { return (typeof(Joint).Name); }
public override string TypeDescription
get { return ("Joint"); }
public override BoundingBox Boundingbox
get
if (Value == null) { return BoundingBox.Empty; }
return Value.GetBoundingBox();
public override BoundingBox GetBoundingBox(Transform xform)
return Value.GetBoundingBox(xform);
#endregion
#region casting methods
public override bool CastTo<Q>(out Q target)
//Cast to Joint.
if (typeof(Q).IsAssignableFrom(typeof(Joint)))
if (Value == null)
target = default(Q);
else
target = (Q)(object)Value;
return true;
//Cast to Mesh.
if (typeof(Q).IsAssignableFrom(typeof(GH_Mesh)))
if (Value == null)
else if (Value.GetMeshes() == null)
else
target = (Q)(object)new GH_Mesh(Value.GetMeshes());
return true;
return false;
public override bool CastFrom(object source)
if (source == null) { return false; }
if (typeof(Joint).IsAssignableFrom(source.GetType()))
Value = (Joint)source;
return true;
return false;
#endregion
#region transformation methods
public override IGH_GeometricGoo Transform(Transform xform)
if (Value == null || !Value.IsValid) return null;
var transformedJoint = Value.Duplicate();
transformedJoint.Transform(xform);
return new JointGoo(transformedJoint);
public override IGH_GeometricGoo Morph(SpaceMorph xmorph)
return null;
#endregion
#region drawing methods
public BoundingBox ClippingBox
get { return Boundingbox; }
public void DrawViewportWires(GH_PreviewWireArgs args)
if (Value == null) { return; }
if (Value.LWashers.Count > 0)
ProcessWasherEdges(Value.LWashers, args);
if (Value.SWashers.Count > 0)
ProcessWasherEdges(Value.SWashers, args);
foreach (Arm arm in Value.Arms)
args.Pipeline.DrawCurve(arm.Outline, System.Drawing.Color.Aquamarine, 2);
foreach (Hole hole in arm.Holes)
args.Pipeline.DrawCurve(hole.Curve, System.Drawing.Color.Aquamarine, 2);
foreach (Chock chock in Value.Chocks)
args.Pipeline.DrawCurve(chock.Outline, System.Drawing.Color.Aquamarine, 2);
foreach (Hole hole in chock.Holes)
public void DrawViewportMeshes(GH_PreviewMeshArgs args)
private static void ProcessWasherEdges<T>(IEnumerable<T> washers, GH_PreviewWireArgs args) where T : Plywood
foreach (var washer in washers)
Curve crv = washer.Outline;
Plane plane = washer.Plane;
var offsetCurve = crv.DuplicateCurve();
switch (washer.OffsetType)
case OffsetType.Up:
// Никакого смещения не требуется
break;
case OffsetType.Middle:
offsetCurve.Transform(Rhino.Geometry.Transform.Translation(-plane.ZAxis * washer.Thickness / 2));
break;
case OffsetType.Dawn:
offsetCurve.Transform(Rhino.Geometry.Transform.Translation(-plane.ZAxis * washer.Thickness));
break;
default:
throw new Exception("У объекта не указано направление выдавливания.");
args.Pipeline.DrawCurve(offsetCurve, System.Drawing.Color.Aquamarine, 3);
#endregion
You need to override read and write methods. Below is an example based on the read and write methods of the Javid Bitmap parameter:
public override bool Read(GH_IReader reader)
m_value = reader.GetDrawingBitmap("Bitmap");
return true;
public override bool Write(GH_IWriter writer)
if (m_value != null)
writer.SetDrawingBitmap("Bitmap", m_value);
return true;
These methods handle the serialization and deserialization of the ‘Bitmap’ data. For a complete reference, you can review the GH_Bitmap class in the Javid repository on GitHub at: Javid/Javid/Parameter/GH_Bitmap.cs at master · mahdiyargit/Javid · GitHub .
