Insert point to mesh or SubD BUG
Hi, I recently update my Rhino to the last SR 8.6 and I noticed that the command Insert point to mesh or SubD doesn’t work if on the object the SubD simmetry is also active. I made a few tries just with SubD primitives, on the same object the command that regularly work, after the simmety is activated doesn’t make changes anymore. (of course working on the lighter “active” area of the simmetry).
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commercial, build 2024-04-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
> Accelerated graphics device with 8 adapter port(s)
- Windows Main Display attached to adapter port 0
- Secondary monitor attached to adapter port 1
- Secondary monitor attached to adapter port #2
Secondary graphics devices.
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Users\samuele\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\samuele\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
file and steps to repeat?
Hi, Kyle
What I’m doing is just to run that command before and after I applied the simmetry on the SubD object.
Here in the file I attached the same object is duplicated. One with the simmetry the other without.
test.3dm (77.3 KB)
I think it’s this:
https://mcneel.myjetbrains.com/youtrack/issue/RH-81085
you are correct-
this is a stop ship item that will be fixed asap.
