When I insert a (3dm)file in a new file as a block, ‘linked’ and ‘active’, and in my new empty file the perspective or back-front viewport is active, the block is inserted on a different location in the file as well as turned around. Also when the grid settings don’t match in both files, the location of insert is also different.
With the grid settings matching and top viewport active there’s no problem.
note: all my files, blocks and objects refer to the same world zero.
Anyone of you out there have any experience with this issue?
Hello - Insert pays attention to the current construction plane.
