thomasn
(Thomas Niederberger)
June 22, 2018, 1:35pm
1
I often insert site plans as blocks in the drawing file. In V6 the inserted block shows strange lines / as well it is snapping to lines that are not visible…
when exploding the block, lines are changing and are shown correctly.
Initial File, that is afterwards inserted as block
https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/c/f/cfd2f20ae113b8cc472b533d1f3f85494790b6ed.mp4
Drawing file in which the initial file is inserted (as referenced block)…
https://global.discourse-cdn.com/mcneel/uploads/default/original/3X/9/8/98948c33a9c99ee7b97ec87935e5d5700d21c380.mp4
pascal
(Pascal Golay)
June 22, 2018, 3:26pm
2
Hi Thomas - my guess is the objects have been inserted very far from the world origin - is that the case?
thomasn
June 26, 2018, 7:35am
3
Yes. So the only way to solve that is to change the position in the original file?
stevebaer
(Steve Baer)
June 26, 2018, 2:32pm
4
This should be fixable; @thomasn or @pascal do you have a sample that shows the bad behavior?
pascal
(Pascal Golay)
June 26, 2018, 2:57pm
5
Hm. I’m trying to make one and it looks fine tens of millions of units out…
thomasn
June 27, 2018, 7:48am
6
I can send the file but do not want to post it here… Whom can i send it to?
nathanletwory
(Nathan 'jesterKing' Letwory)
June 27, 2018, 7:50am
7
@thomasn , you can upload it to rhino3d.com/upload and mention steve in the comments, perhaps even copy the link to this discussion ( Display Problem when working with blocks ) in the comment section. The file will find its way to Steve.
