is there a way to avoid that the parent layers of linked blocks always switch back on after re-opening the file.
We have a quite large project structure with many linked blocks and it is time consuming to correct the layer display configuration each time after re-opening.
Thanks Pascal,
That helps a bit. Is there a way to overwrite a stored state? Like when selecting a view and pressing the save button it allows you to overwrite it. Otherwise it is a tedious process.
This is a really harmful behaviour of Rhino (Rhino 7 in my case). I constantly combat these self-opening block layers after opening some file again where the saved state of those layers was off.
Is there any intention by the developers to fix this particular bug?
