I can’t think of any good solution to orient a small connection part into a larger model.
It would be great and helpful if I could get some advice here.
Following is a photo of the two models and a GH file of them.
It works well on this large model, but sadly it won’t work on other large models.
Thanks anyway! It did give me an insight into how to solve a problem like this!
I used this code on my other models and it works perfectly on nearly every model that I have!
And I will try to understand now how this solution works.
It really helps and I appreciate your time and efforts
The algorithm I used depends on one of the semicircular faces of the “biscuit”/“domino” tenons (connectors) for both location and orientation. Matching is weak as it depends only on area, though that could easily be improved by comparing area AND perimeter length AND discontinuity points (2). The tolerance value of theisEqual cluster (‘T’ input) could be increased from its default of 0.0001,
If you post an example where it fails, I’ll take a look at it.
Thank you for the thorough explanation!
With this explanation, it’s much clearer how the algorithm works.
So far, only one model has failed with this algorithm, probably because there are negative spaces that are not perpendicular. I will try to fix that myself first.
I want to extend the functionality of this algorithm a bit further. My Goal:
Because some of the connectors will exceed the boundary of other models, I want to check if they are intersecting with the other models and remove them accordingly. Some need to be replaced with ‘half-connectors’. I tried with List Length (smaller intersecting area, fewer curves), but it didn’t work.
Would it be possible for you to take a quick look at this? I would really appreciate it!
This started simple with the white group, using SDiff to “subtract” a BBox from all the blue connectors (before they were blue). But that left some cut off connectors in the same places where the pink connectors are… So the cyan group is an elaborate scheme to leave only the blue connectors you see, leaving out those that overlapped the pink connectors.
Thank you very much for the help and the elaboration is clear for me to understand!
Also, thank you for the Pshift tip. I will use it to replace Path Mapper
I am really sorry for the large GH file that caused unpleasant problems.
I will look into it to see if I can downsize or simplify the geometry.
I realize that internalizing geometry is standard practice for the forum. When that geometry is small, it’s no big deal.
But when the geometry is large, as in this case, it causes me grief - especially when multiple versions (copies) are involved. Small changes to the GH code require multiple copies of the huge file. In these cases, keeping the large geometry in a Rhino file that small GH files refer to makes more sense. Or have a single GH file with large internalized geometry using Data Output to pass it to “real GH” files (the bits that manipulate the geometry) to access it using Data Input.
For example, you don’t need multiple copies of the connector. Instead of this:
Thank you for the very detailed explanations!
This information is indeed something I need.
I’ve been bothered for a while about how to downsize the file and/or speed up the calculations.
I will apply your suggestions to a larger file that I’m currently working on and make sure to post something like this if the geometry size is too big.
