is there a way to have a table inside the grasshopper environment to input values in rows with columns.
Right now I have 4 panels to input values, but I have to make sure they have the same index because theses inputs relate to each other. I can not find table it in the input tab, is there a plugin or anything like that?
Thanks so much for writing that plug in, works great.
Got a questions, you know how I can get the values from it with Python as an GH.object?
I’m writing a small script to export all inputs to a csv file, I managed to get all the values from the sliders using:
ghObjects = ghenv.Component.OnPingDocument().Objects
for obj in ghObjects:
print type(obj)
if type(obj) is gh.Kernel.Special.GH_NumberSlider:
print obj.NickName
print obj.Slider.Value
When I print all the object I can see and object called: “<type ‘TableDataInputComp’>” I suspect its this one.
you have an idea how to get the values from it and the NickName?
In the future, objective is to than control it from a CSV as well.
@Mahdiyar Unfortunately, the TableData input component doesn’t scale with my monitor’s DPI. On a 4k screen, the text is very small. Is this something you could address?
