Inititalize Rhino Python on csharp startup
I am working on a Rhino 8 C# plugin that calls Python 3 methods at runtime. The reason for mixing languages is that we have an internal Python package with functionality I don’t want to replicate in C#.
The issue I’m running into is that the Python 3 language runtime is not initialized when my plugin loads. Specifically, RhinoCode.Languages.QueryLatest(new LanguageSpec("mcneel.pythonnet.python")) returns null until the Script Editor has been opened at least once in the session.
My current workaround is using:
RhinoApp.InvokeOnUiThread(() =>
RhinoApp.RunScript(“_ScriptEditor _Close”, false)
This is my current Test Command:
using Rhino;
using Rhino.Runtime.Code;
using Rhino.Runtime.Code.Execution;
using Rhino.Runtime.Code.Languages;
using System.IO;
using System.Reflection;
namespace Commands
public class PythonTestCommand : TrnBaseCommand
public override string EnglishName => “PythonTestCommand”;
 protected override Rhino.Commands.Result RunCommandLogic(RhinoDoc doc)
        // 1. Get Python 3 language
        var language = RhinoCode.Languages.QueryLatest(
        if (language is null)
            RhinoApp.WriteLine("ERROR: Python 3 language not available.");
            return Rhino.Commands.Result.Failure;
        // 2. Load embedded script and append the function call
        string? pythonCode = LoadEmbeddedScript("Scripts.PythonTest.python.py");
        if (pythonCode is null)
            RhinoApp.WriteLine("ERROR: Could not load embedded Python script.");
        double[] data = new double[] { 1.0, 2.5, 3.7, 4.2, 5.9 };
        string dataLiteral = $"[{string.Join(", ", data)}]";
        pythonCode = pythonCode + $"\nresult = run({dataLiteral})";
        // 3. Create code object
        var code = language.CreateCode(pythonCode);
        var outputStream = new MemoryStream();
        var ctx = new RunContext
            OutputStream = outputStream
        code.Run(ctx);
        string output = System.Text.Encoding.UTF8
            .GetString(outputStream.ToArray())
            .Trim();
        RhinoApp.WriteLine($"[PythonTest] {output}");
        return Rhino.Commands.Result.Success;
    private static string? LoadEmbeddedScript(string resourceName)
        var assembly = Assembly.GetExecutingAssembly();
        using var stream = assembly.GetManifestResourceStream(resourceName);
        if (stream is null) return null;
        using var reader = new StreamReader(stream);
        return reader.ReadToEnd();
Can anybody point me into the right direction or provide ressources?
does this help:
Thanks @Willem ,running a dummy script for me did the trick. I just added a warmup.py and let that run on OnEndDocumentInitialViewUpdate() Event
private void AddPython()
string tempPath = Path.Combine(Path.GetTempPath(), “MyPlugin_warmup.py”);
File.WriteAllText(tempPath, “pass\n”);
     RhinoApp.RunScript($"_-ScriptEditor _R \"{tempPath}\"", false)
My warmup.py i just:
pass
After that i am able to just run my commands and methods that use other python scripts :slight_smile: !
