Hi!
I have struggled for a while now with a beizer span where I would like to affect the start and end beizer with different factor values. Since I need the curves attached to two curves a Tween Curve will not work.
In the attached images it is curve A and B I want to affect individually and get a number of curves in-between.
Please let me know if I need to explain better.
Thanks in advance.
beizer span 001.gh (16.3 KB)
This way lets you give a range of values for each Vector Factor. They just vary linearly between the 2 slider values but you could change the Graph Mapper type if you want a different type of change or you could create a Series of numbers instead.
beizer span 001.gh (26.5 KB)
Great! It worked perfect for the solution I was looking for. After changing to beizer graph mapper it even made a more precise control for my case, so thanks for that suggestion as well.
Yeah, the Bezier Graph Mapper is my favourite too!
