I was wondering if the “Index out of range” had a specific meaning.
It appeared from the following code, and was caused by a layer name not having enough “;” I deducted.
def search_corresponding_layer(attributes_to_correspond, serial_num):
layers = rs.LayerNames()
found = None
if layers:
for layer in layers:
layer_parts = layer.split("::")
if len(layer_parts) < 2: continue
if layer_parts[0] != serial_num: continue
if not layer_parts[1].endswith("_3D;"): continue #only match to 3D
last_layer_part = layer_parts[-1]
bits = last_layer_part.split(";")
if len(bits) < 3: continue
if bits[-1] == "[BLOCK]": continue #dont look in BLOCKs
attributes_bit = bits[1] #only SrNr
if attributes_bit == attributes_to_correspond:
found = layer
break
return found
if layers:
always = False
levels = layer.split("::")
#we skip all layers that are not at level 2
if len(levels) != 3: continue
level1 = levels[1] #get the 2D-3D sublayer part
if not level1.endswith("_2D;"): continue #only tackle "_2D;" layers
level2 = levels[2] #get the complicated part
all_bits = level2.split(";") #get tokens that make up the complicated part
first_bit = all_bits[0]
last_bit = all_bits[-1]
central_bits = all_bits[1] #Only SrNr.
if last_bit != "[BLOCK]": continue #just do something if last bit is [BLOCK]
part_to_correspond = central_bits
new_layer = search_corresponding_layer(part_to_correspond, levels[0])
if new_layer is None:
#feedback outcommented
#rs.MessageBox(part_to_correspond + "\n\n" + "Correspondence not found. Will just continue")
print("\n" + "No correspondence for: " + part_to_correspond)
continue
print("\n" + "Layer name to be changed:")
print("FROM: " + layer)
print("TO: " + new_layer)
answer = None
if not always:
answer = rs.GetString("...do you agree?", "Yes", ["Yes","No","Always"])
if always or answer:
if answer == "Always": always = True
elif (answer is not None) and (not answer.upper().startswith("Y")): continue
layer_parts = new_layer.split("::")
new_name = layer_parts[2]
print(new_name)
rs.RenameLayer(layer, new_name)
else: break
“Index out of range” means you are trying to access an array element with an index that doesn’t exist.
From a quick glance and without counting line numbers I’d guess your problem is:
You assume that the split operation always has at least three parts and access the third. If split produces two parts or less, you will get an “index out of range”.
