Is there a way to access the selected English Option Value?
GetString getString = new GetString();
getString.AddOption(*EnglishOption*, *EnglishOptionValue*);
I can:
var aa = getString.Option().LocalName;
var bb = getString.Option().EnglishName;
var cc = getString.Option().StringOptionValue;//Null
var i = getString.Option().CurrentListOptionIndex;
But I do not see:
var ee = getString.Option().EnglishOptionValue;
var ff = getString.Option().LocalOptionValue:
Just trying to use it as a way to set a Layer Name. I can do it a different way but this is a straight forward way of getting a valid Layer name from a simple get operation. Most classes I have worked with have carried this stuff through but there are lots of ways around this. I just wanted to make sure I was not missing anything before I implement.
public void SetLayout(
ref AsaPageView asaPageView,
double PageWidth,
double PageHeight
getString.AddOption(“Default”, “Project Name”);
getString.AddOption(“Standard”, “Project Name1”);
getString.AcceptString(true);
getString.SetCommandPrompt(“Do you want to add a layout for your stuff (enter to bypass)”);
getString.Get();
if (getString.CommandResult() == Result.Cancel) return;
if (getString.CommandResult() != Result.Success) return;
***string stringOutput = getString.Option().EnglishOptionValue;***
if (string.IsNullOrEmpty(stringOutput))
//User only has one option. If this was an option list we would need to go another route
stringOutput = _ProjectName;
//Id nothing is selected exit
if (string.IsNullOrEmpty(stringOutput)) {return;}
if (stringOutput != null)
//Return either an excising Layout or create a new one.
RhinoPageView newPageView =
asaPageView.GetPageView(stringOutput)
?? asaPageView.CreatePageView(stringOutput, PageWidth, PageHeight);
if (newPageView == null)
RhinoApp.WriteLine("Layout could not be created.");
else
_doc.Views.ActiveView= newPageView;
