Hi all,
Is there any way to set a localized string to the mehotd AddOptionEnumList method in the GetPoint class?
Other similar methods have a LocalizeString object as input parameter.
Regards,
Hi all,
Regards,
If your strings are stored in a localized version of a resource file, then something like this might work for you.
http://www.codeproject.com/Articles/19953/Localizing-NET-Enums
– Dale
Hi Dale,
Thank you for your answer. That solves the localization for the Values of the enum not the Name of the option. I think I didn’t explain well.
What I mean is almost all the AddOptionMethods have as input parameters a LocalizeStringPair:
AddOptionDouble(LocalizeStringPair, OptionDouble)
but the enum one doesn’t have a LocalizeStringPair as an input parameter for the name of the option, only the english string:
AddOptionEnumList(string englishOptionName,T defaultValue)
Then, If I put the localized string into the englishOptionName
parameter, the user can’t use the command in scripting mode unless his language is english.
Regards
Because AddOptionEnumList
isn’t easily localized, use AddOptionList
– Dale
