I’m trying to export points with coordinates from MSTN v8i ss5 to Rhino 6 or 7. The Microstation model is centered around GobalOrigin (0,0,0) with units in mm and the test object is about 10x10 meter. Rhino can import DGN and the file units are set to mm, large objects. However, the coordinates are inflated immensely, about 10^6 times. Any clue how to get it right? Greetings, Ingemar
