Import Material from Materials Library
Looking for a way to import a custom material from a library of materials I am developing. I want to import these materials into the Rhino document and then assign them by selection to different objects. Is this possible?
I would use command line scripting if necessary.
To do this manually I use ‘import from material library’. Can use Rhinoscript or Rhino API using Python.
Thanks
Eric
Hi @eric.bunn,
Try scripting the Materials command.
– Dale
Dale,
Thank you. I think this should work for me.
rs.Command("_-Materials Options LoadFromFile _Browse AssignToObjects Instamate _Enter _Enter")
Eric
