I need to Script{or command } to Import all new Display modes Simultaneously with just one click to Rhino
or This is possible in the new update of Rhino 6 and 7*{For example, by dragging(*.ini) on the Rhino screen}*
Because * .ini files are currently entering Rhino one by one
And that’s a lot of tedious and time consuming files
@pascal
@wim1
Maybe try import options and check only View checkbox. You need fist to export the options where display modes are.
Hi, you can try the script below - it should let you pick the ini files and import all at once…
Option Explicit
Call Main()
Sub Main()
Dim arrFiles : arrFiles = Rhino.OpenFileNames("DisplayMode Files to import?", "DisplayMode Files (*.ini)|*.ini|All Files (*.*)|*.*||")
If isnull(arrFiles) Then Exit Sub
Dim i
For i=0 To Ubound(arrFiles)
Call Rhino.ImportViewDisplayMode(arrFiles(i), True)
Next
End Sub
thanks very useful
You can use this version:
ImportMultipleDisplayModes.rvb (537 Bytes)
Just save on your HD and drag-and-drop into Rhino vport - it will add Alias/command:
excellent
Here you go (same instruction as below, save on HD, drag into Rhino vport; from then on, the alias will be: ImportMultipleHatchPatterns )
ImportMultipleHatchPatterns.rvb (568 Bytes)
Thanks
@Jarek
Hey, I had a question about the Rhino.ImportViewDisplayMode. Has this been implemented to rhino common or is there a way to do it with rhino common
I don’t know RhinoCommon too well, but seems like this should help:
DisplayModeDescription.ImportFromFile Method (rhino3d.com)
