Hello!
When objects are overlapping, selecting them opens a popup menu which lets you choose, which object you want to select.
Is there anyway to implement an own popup menu which then gets used instead?
The use case I have is the following:
CRhinoGetObject go; go.SetCommandPrompt( L"Select objects" ); CRhinoGet::result res = go.GetObjects( 1, 0 );
I have special, “hidden” objects - relations, which are connected to the objects. While the user is selected objects, e.g. some mesh, I want to show him my own pop up menu to allow him to decide between the mesh or my “hidden” relation.
Best Regards.
