Hi There. I am working on creating something I have been sketching by hand for a while and want to see how I can iterate it with GH by just moving the initial points and changing the border. I’m a novice with GH and figured this is a good way to learn, but I am at a standstill.
Geom Sketch 001.3dm (43.3 KB)
See attachment for steps. I am stuck at Step 4.
I can make the red shape with all rounded corners using Nurbs Curves or Splines, but what I think I need to do is analyze the angle of the lines generated from Step 2 and use that to determine whether the corner is rounded or sharp. The rule I have made for myself that I think could be an IF statement is: If the interior angle is <= 90 deg then it is rounded with a Nurbs Curve. If it the interior angle is > 90 deg then it is sharp as shown.
I have found tools to analyze the angles, but have not found any ways to make GH use that to make a decision between the two options. I have tried kinky curve but have not had much luck. I have looked into If Statements in GH, but the examples I’ve found don’t let me tell GH “If this angle, then make this. Else make this.”
Thank you!
