Is there a way to create if else statement like this one?
if 0<x=<0.2 is true, y =1
if 0.2<x=<0.4 is true, y =2
if 0.4<x=<0.4 is true, y =3
if 0.6<x=<0.8 is true, y =4
if 0.8<x=<1.0 is true, y =5
Thank you,
I just decided to use python instead.
Be sure to share your Python solution? Hard to believe it would be simpler than what @akilli posted.
here is the script
if x <= 0.2 and x >= 0:
print (β1β)
if x <= .4 and x > .2:
print (β2β)
if x <= .6 and x > .4:
print (β3β)
if x <= .8 and x > .6:
print (β4β)
if x <= 1 and x > .8:
print (β5β),
then convert it to a number.
print (β1β)
print (β2β)
print (β3β)
print (β4β)
print (β5β)
That produces an error:
Runtime error (SyntaxErrorException): unexpected token βββ
File ββ, line 2
print (β1β)
SyntaxError: unexpected token βββ
This works better:
a = 1
a = 2
a = 3
a = 4
a = 5
Do you understand what @akilli posted? Itβs better than a series of βifβ statements.
Math
if you don t care about includiung 0 and values below 0 or above 1
you can also use
y = Ceiling(x/0.2)
(Ceiling β round up to next integer equal or bigger
Floor β round down β¦)
title / topic
and as the title of your topic might direct someone with a complete different question:
The Sift+Combine pattern is designed to mimic conditional clauses (i.e. βif statementsβ). It allows you to pull apart a stream of data, operate on subsets of that stream and then put it all back together again in the same order.
from the old forum
Find Domain is far more flexible than a series of hand coded βifβ statements:
find domain_2023Feb19a.gh (12.9 KB)
True, I will use that for the future.
Thank you for the help and script it is very much apricated.
Stream filter (or stream gate) worked well for me for a true/false if/then filter.
