hello,
i would like to make these queries of the lists in x and y and as a result have a list again after the query if then. can someone help me please?
best regards, michael
hello,
I expect that this is a type problem. Those are string values coming into the Grasshopper component. To run the ==
on numbers them they need to be Integers or Floats. Right clicking on the inputs x and y and setting type hint to Float should solve the problem.
print(type(x))
can be watched on the out port.
hi @scottd ,
thanks for your response. I tried that with type hint but that’s not the problem.
use type hint int, then press play in the code editor
PS:sometimes the python compiler doesn’t work properly. the work around to that is to create a new battery, paste the code, press play
Send the def here if you want I can take a look. Internalizing the lists in a component will help.
Does this one work for you?
py3-int.gh (12.4 KB)
Hi @scottd @adel.albloushi @fcegnam ,
thanks for your help. now it works!
Kind regards
