I want to line up a bunch of irregular holes and use them for processing.Guarantee the distance of the hole, can not crisscross。
Help Us Help You
3. Attach minimal versions of all the relevant files
If you have agh
file you have a question about, attach it to the post. Do not expect that people will recreate a file based on a screen-shot because that’s a lot of pointless work. It’s also a good idea to remove everything non-essential from agh
file. You can use the Internalise Data menu option to cut everything to the left of a parameter:
Simplifying a Grasshopper network
If you are referencing curves or breps or meshes from Rhino, you can also internalise them so you won’t have to post a 3dm
file as well as a gh
file. If you’re unsure whether all the relevant data is internal to the gh
file, try opening it in an empty Rhino. Does it work? Good. No? You’ll need to internalise more.
