I try to rectangle on ceiling of the model but i can't in x and y-axis
i try to put rectangle on ceiling but I can’t why
and also, sometime ( line or crv ) also behave like that why
There is a command called 3pt rectangle. That might help. You could also Loft between two edges. Do you have any Cplanes active besides default? —-Mark
yes i guess
good idea
but
but y this happens someone explain and send video if u have good time guys
markintheozarks
I feel like you are just starting with Rhino. Have you seen the Free training content on the McNeel website?
ya but if u have solution, then u can tell that would be helpful
and i used more than 100 days learn still upto take render
but i have some question in mind to not clear thatsy I’m here i know by another way to doit
but i wish to learn fully with understanding
Rectangular Plane by 3 points command?
Yes you will find help on the forum
the question when i use rectangle crv
and need to place the rectangle crv on ceiling (i know we can use srf option commands)
why i can’t do that
but line crv can fit into x axis and y axis and z axis
rectangfle.3dm (79.4 KB)
The Little Triangle in the corner opens more options for the rectangle tools
Screenshot 2026-11-03 163238
I am just about to log off my work computer for the day (uk time). So I hope others can jump on this chat
CPlane command - set it to the ceiling level. then draw the rectangle
EDIT: I think the CPlane (Construction Plane) is like a piece of paper. To draw a circle you need a 2D flat piece of paper to draw on. You can move the CPlane around but World Origin stays the same.
EDIT 2: Google AI says “Restoring defaults: You can reset the CPlane back to standard orientations (such as World Top, Front, or Right) at any time using the CPlane command with the World option”
