Hi. I have two points on a curved surface. How can I know the shortest way from one to the other on the surface? Thank you!!
In regular Rhino you use the ShortPath command which creates the shortest curve between two points on a surface. I don’t know what the Grasshopper equivalent is, if there is one.
It must be geodesic.
What must be geodesic? The result of ShortPath is the geodesic curve between two points on a a surface.
The component is called Geodesic
Perfect perfect!!!
thanks!
