Hi @nathanletwory,
I’m having another issue: I can’t get a fully dark image.
I was used to a trick in V7 were I could put a very dimmed light to get a really dark image.
I do this when I don’t want to have any environment affecting the image.
With the latest version 8 I’m always getting an annoyng back light from an EnvMap … not set by me!!
I see but isn’t working if I switch ALL the environment map off.
When all the Envmap are off a default one appears no matter if I have light or not.
Is this an intended behaviour?
ah… yes… you have to actually have the environment lighting enabled but at a tiny amount, or rhino throws a default light set up into the scene.
If you don’t have environment lighting or skylight, or any physical lights in the scene it’d be black… so rhino throws a default directional light into the scene.
By the way, in latest Rhino 8 if you have an object with an emissive material in a scene without any lights the default light won’t be enabled anymore. The object with that material now functions as the light source.
