I created a console project with Rhino.Inside (via nuget) to generate a json for each 3dm file.
My code it’s very similar to this sample: rhino-developer-samples/rhino.inside/dotnet/SampleConvert/Program.cs at 7 · mcneel/rhino-developer-samples · GitHub
However it crushes each 2-4 files, with this error:
Unhandled exception at 0x00007FFE052B49EE (ucrtbase.dll) in Analyze3dms.exe: Fatal program exit requested.
internal class Program
static Program()
RhinoInside.Resolver.Initialize();
[STAThread]
static void Main(string[] args)
try
using (var rhCore = new RhinoCore(new string[] { "/NOSPLASH" }, WindowStyle.NoWindow))
var destinationFolder = @"C:\...";
var folders3dm = new string[] {
@"C:\..." , @"C:\...", @"C:\..."
var map3dm = new Dictionary<string, string>(); // maps file name to file path
foreach (var folder in folders3dm)
var files = Directory.GetFiles(folder, "*.3dm").ToList();
if (files.Count == 0)
foreach (var subFolder in Directory.GetDirectories(folder))
files.AddRange(Directory.GetFiles(subFolder, "*.3dm"));
foreach (var file in files)
var name = Path.GetFileNameWithoutExtension(file);
if (map3dm.ContainsKey(name))
//Console.WriteLine($"{name} duplicated: {map3dm[name]}, {file}");
else
//Console.WriteLine(name);
map3dm.Add(name, file);
var counter = 0;
foreach (var kvp in map3dm)
counter++;
var newJsonFile = Path.Combine(destinationFolder, kvp.Key + ".json");
if (File.Exists(newJsonFile))
continue;
Console.WriteLine($"{counter}/{map3dm.Count} | {kvp.Key} | {kvp.Value}");
var doc = RhinoDoc.Open(kvp.Value, out _);
if (doc == null)
Console.WriteLine("doc is null");
Console.WriteLine();
continue;
var sku = SKU.CreateFrom3dm(doc); // This just reads layer info, it's not causing the problem bc I'm getting same error if I don't execute it.
//doc.Dispose(); // I tried with and without Dispose, no difference.
SKU.WriteJson(newJsonFile, sku);
System.Threading.Thread.Sleep(1000);
catch (Exception ex)
Console.WriteLine(ex.Message);
I’m quite sure the problem is at openning the doc.
I had written this far when I tried to disable “Enable native code debugging” and this has eliminated that error.
However, the problem continues. I can randomly process 1 to 20 files without problems, but it either stops on its own, or it doesn’t progress, or I get an error: System.AccessViolationException: ‘Attempted to read or write protected memory. This is often an indication that other memory is corrupt.’
- What else can I try?
- Is there a way to load RhinoInside without plugins?
- Can I load Rhino 8 instead of Rhino 7?
I can share the project and files with some McNeel stuff.
Thanks.
